it can be very useful if Multiecuscan would be able to connect to Marelli IAW 49F found in my '98 Fiat Punto. I tried using Bravo/Brava/Marea 1.6 49F settings but it didn't work.
Hope this feature will be added soon.
Obviously a 3-pin adapter is a must.
Thanks and kind regards
Fiat Punto 1.2 8v 75CV Marelli IAW 49F
style.suite
Re: Fiat Punto 1.2 8v 75CV Marelli IAW 49F
IAW 49F is not listed for Punto, in http://multiecuscan.net/SupportedVehiclesList.aspx
Tried MES locates the module by SCAN option?
Sorry for bad english...
Walter, from Brazil
Walter, from Brazil
style.suite
of course yes I tried mes scan to find the most suitable module but found none. I will post here the ecu codes resulting from scanning, maybe they'll help finding a similar one or, why not, add support in a future release.
Regards
Regards
Have you tried IAW Scan 2? I used it on a 1.2 16V that was unsupported by MES, and it worked fine: http://iaw-scan2.sourceforge.net/
Most Puntos 75 (mk.1, 1.2, 8V, MPI) had an IAW-8f.5T ECU, IAW-49F was extremely rare ECU in Punto mk.1 (only '98-'99). Maybe you will succeed connecting as a Punto II 1.2 8V ('99). The Punto '98 75 is listed, but it's ECU is not supported.
