Brera proxy allignment
okie dokie then after adding a dusk sensor and column stalks to match the car is not recognising these additions would running a proxy alignment help and I see it also says in doing this you may need the cars 5 digit security code where would I find that
Re: Brera proxy allignment
to get 5 digit security code you have 2 options:
option 1: buy it in official service. In some countries it cheap and in the other one it is expensive.
option 2: go to one who can read code from body ecu.
you can also post file (aka dump) here and I will calculate code for you!
I do not think you will need code for proxy...
I never needed.
Thanks Alfa
