Is it possible to read out the Engine ECU of my Ducato (Typ 250 Facelift) 2.3 JTD (130hp) mj:2012 Euro5
I use the latest registrated version 1.2R1
Engine ECU is not included in the list of Systems for that Car ??
Thanks Brera 32
Latest Ducato 2.3 ECU Euro5
Re: Latest Ducato 2.3 ECU Euro5
Did you tried to do scan of all systems - F11 button?
Maybe you can try to connect with some older model of Ducato or some other car which has similar engine ecu...
Didn`t try to scan the system.
But i tryed the pre Face Lift Model.. but it didn´t work.
Will try to scan the System next time i have the Car in my garage.
thanks..
thanks..
alexandre.spp
hi i have the same problem on the 1.5 multiscan ,i have the Fiat Ducato 2.3 multijet economy 2012/2013 to DPF regeneration and clear the oil change light of the engine, to my surprise the program opens all other models of van Fiat Ducato (244) and before but when I try the Ducato (250) Facelift 2.3 Multijet ECU Magneti Marelli 8F3 CF5/EOBD DIESEL INJECTION (2.3) come whith error connection ELM 327. what can be? i use the ELM 327 V1.3.
I did an oil change on a 2013 Fiat Duacato motorhome, 2.3, 150HP.
It detects it as 250 facelift, parameters display fine.
However cannot execute an oil change, "executing failed " or something like that.
Interestingly I did not notice there was an error on the first try (maybe just did ont read), but nothing changed.
(same oil degradation, zero oil changes)
Then reset the service, but it does not help.
(Also tried as regular 250 (no facelift), but it does not connect that way.)
Am I doing something wrong ?
ELM 327 V1.4
Meanwhile the oil has already been changed, so I would like to reset it as soon as possible ... this was one of the main purpose of purchasing the program.
What can I do ?
ELM 327 V1.4
What can I do ?
Repeated the procedure and worked somehow this time.
Not sure what made the difference, as about 2 km distance was indicated for the oil change maybe the first time attempt needed some travel to take effect ?
Anyhow, glad it finally worked.
did change the oil in this model several times, the procedure goes for the second third time
I'm using 1.3 ELM327
greet
greet
