Alfaeddy wrote:Hello Cristian
I am glad that I could help you![]()
thank you Eddy, so i have to remove only the resistor marked in red? nothing else?
I'm using my android phone with bluetooth so what driver should I install?Alfaeddy wrote:Hello Veskoy
Your connection problem is not the bridge resistor but
probably a wrong driver.
Because the ECU on your Punto is not read by CAN bus, but with
KWP2000 and there is no function of the resistor R34
Charging you this driver and try again.
Only for Body Comp. / Elec. Steering /, Proxi Alig. is read via CAN bus.
and since disturbs the resistor R34
Yes the battery is fully charged. The problem is that before I removed the resistor I was able to connect with Torque (free). Now I can't connect neither with Torque nor with AlfaOBD.Alfaeddy wrote:Hello Veskoy
Oh! You're working with AlfaOBD Androit, I have not read![]()
Here, no driver is needed.
Is the battery charged?
Some had connection problems, it was the almost empty battery
Let the engine run
