Hey,
first to the problem:
in Dynamic mode of my Alfa 1.4 16V MiTo, the servo is smoother on the
right side, than it is on the left side. There is a bigger angle on the right side to
steer the same degree as on the other side, so it isn't that "directly" than on the left side.
Also at higher speed levels, the steering is soft and not that strong it should be to feel safe.
So could it help to reset the steering-controler ?
I asked at Alfa Romeo to do that for me, but they said it is not possible to reset steering parts.
Is that right?
Thanks for all answers !
could it fix the servo? HELP
Marvin1908
Re: could it fix the servo? HELP
Hello Marvin
If I understand it correctly, the force required for the steering wheel is different ??
With Multiecuscan can calibrate the force setting new
That should help you
And the Alfa Romeo garage, this should also be able
Edit:
I wanted to hire you a picture with the description here
Unfortunately, I can put here any more images
And also do not know why ??
Edit:
Marvin1908
Yes you got it!
Thanks for helping me you just spend more time on it than the "Service"guy at Alfa Romeo...
Okay so I checked out the options and I've done the weel degree reset .
Next I checked the variables of "torque" and degree...
At -2
Torque: 30
At. 2
Torque: 15-20
How can I fix these torque "wrong" e.g. different values?
I tried the torquefix Option, but it failed...
At -2
Torque: 30
At. 2
Torque: 15-20
Some of steering calibration options in MES do not work on newer cars...
Why? Still do not know...
