Hi All
I am new to multiecuscan , i bought the registration for 1 computer and I had problems with the ELM27 Bluetooth not connecting
I want to get a usb wired one , I need to log engine parameters in order make checks for safety before and after remaps , and right now I need to log the following cars:
Fiat 500 Abarth 1.4 Turbo
Alfa Guiletta Quiadrofolie 1.8 Turbo
Which is the best interface for my use , and that can work on windows 8.1 64 bit
Will this be enough and does it work ?? http://www.ebay.co.uk/itm/271552892769? ... EBIDX%3AIT
Thanks for the help
Interface Help for multiecuscan
Re: Interface Help for multiecuscan
hello RS-malta
Did this attention ??
Windows 8 note:
Multiecuscan works fine on Windows 8/8.1, but you have to install .NET Framework 3.5 (which is not installed by default). You simply have to go to Control Panel -> Add remove programs -> Add remove windows components, and install .NET Framework 3.5.
For the CANtieCAR interface you can install the same drivers as Windows 7.
Windows 8 note:
Eddy is right. Check NET framework first...
This interface looks OK...
