Hi guys, I have a Lancia Ypsilon registered in 2009 and I want to install the cruise control.
The car presents the connector in the original wiring, so I have installed the controller and I have activated the function in the body computer with multiecuscan 2.6 (I have activated the function and aligned the proxy). Even if I have activated the function, when I turn it on, the cruise works correctly but the indicator in the instument panel doesn't switch on.
Do you have had this problem?
Thanks, Vincenzo
Problem with cruise control
paolo_bitta
Re: Problem with cruise control
Did you turned "the Light on for cruise control" in body computer or CAN on?
