I have a Fiat Punto mk2b.
What is the node programming sequence order of the PROXI Alignment procedure?
For example, NBC first, then NQS, etc..
Also, is the sequence defined by Multiecuscan, or is it a requirement by the nodes?
I'm asking this because for some unknown reasons Proxi alignment fails on the NQS (Dashboard node), but I may need to do the proxi alignment on the NCM (engine control node).
(I'm trying to enable Cruise Control on my Punto mk2b 1.2 16V, but without proper proxi alignment, i can't do it i guess. My current dashboard doesn't have cruise control light.
The ECU responds to the Cruise Control stalk, according to Multiecuscan, ECU Properties change when I press button, turn on, etc., but displays "Active" when stalk is off, "Absent" when stalk is on.)
Thank you for the help and for the information!
PROXI Alignment sequence order
https://www.puntonium.hu
Re: PROXI Alignment sequence order
I had a same problem! The reason why u get an NQS error is the cruise control led is missing in your dashboard and cant enable cruise control without the led ...
I solved the problem by mount one led to the dashboard, its working perfect now
btw without led the CC also working just u dont have feedback on your dashboard
Well, I have one dashboard with all LEDs in it (almost.. it doesn't have the automatic gearbox led), but still having the NQS error and doesn't writing to other nodes.
