G force tft
G force tft
hello everyone, I ask if anyone can help me, I have a 500 abarth 2012 where I put the tft and set the byte 65 in 60 but the g force does not work, there is a solution ..? thank you...
Re: G force tft
Hi!Maxxx wrote:hello everyone, I ask if anyone can help me, I have a 500 abarth 2012 where I put the tft and set the byte 65 in 60 but the g force does not work, there is a solution ..? thank you...
The g-force and the gas percentage do not work because the bodycomputer of your car is too old and does not provide this information to the odometer.
If you want to view these parameters you have to buy a new and then updated bodycomputer.
Re: G force tft
thank you very much for the information....
fiatnuova500
Re: G force tft
Can i buy a used body computer and reset it with mes?
Whats about the keys ...they must be learnt by the new bcm....
Re: G force tft
You can not use a used bodycomputer, because in addition to the keys you need the injection control unit.fiatnuova500 wrote:Can i buy a used body computer and reset it with mes?
fiatnuova500
Re: G force tft
thanks for your answer, alex. so i have to buy a new body computer. can I do the swap myself and program al with mes or have i to go to a fiat dealer with examiner?
Do you have the part number of the 2015 bcm pre-facelift with g-force support?
Re: G force tft
It is enough that you go to fiat dealer and order a new bodycomputer for your car.fiatnuova500 wrote:thanks for your answer, alex. so i have to buy a new body computer. can I do the swap myself and program al with mes or have i to go to a fiat dealer with examiner?
You will get the one with the updated software.
Just mount it and you will not need to code the keys
fiatnuova500
Re: G force tft
MILLE GRAZIE!
fiatnuova500
Re: G force tft
Today i changed the body computer to a new one.
Gforce is now shown but always 1.2g in all directions.
„Sport“ is always lightning also when sport mode is off. Gas percentage does not work and also gear shift indicator fails in menu and is not shown.
What can i do?
What can i do?
Manuvisentin
Re: G force tft
Hi! Did you find any solution?fiatnuova500 wrote: ↑26 Apr 2018, 19:45 Today i changed the body computer to a new one.
What can i do?
