I tried searching but couldn't find this issue anywhere else.
I have a Giulietta 1.4 Multiair and my radio node stopped working. After i unplugged and replugged the battery, the milage started flashing.
I tried to do a proxy alignment but i get the following error:
Climate Control Node (NCL)
Parking Sensor Node (NSP)
Airbag Node (NAB)
Convergence Telematic Node (CTM)
Receiver Radio/Radio Navigator Node (NRR/RMN)
8/16/2017 8:31:01 AM (Multiecuscan 3.5)
CONNECTED TO:
Alfa Romeo Giulietta 1.4 Turbo 16V
Body Computer Node (NBC): EOL Ok
Engine Control Node (NCM): Ok
Electric Steering Node (NGE): Ok
Dashboard Node (NQS): EOL Ok
Brake System Node (NFR): Ok
Climate Control Node (NCL): EOL Ok
Parking Sensor Node (NSP): Ok
Airbag Node (NAB): EOL Ok
Convergence Telematic Node (CTM): Removed
Receiver Radio/Radio Navigator Node (NRR/RMN): EOL Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (NQS) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
Writing to module: Airbag Node (NAB) SUCCESS!
Writing to module: Receiver Radio/Radio Navigator Node (NRR/RMN) FAILED! - Busy error
FAILED TO EXECUTE
I tried this multiple times but without any success.
Any idea how i could disconnect the radio from CAN so that it won't drain my battery until i arrive at a garage ?
Many thanks !
Proxy Alignment error: Radio/Radio Navigation Node Busy error
didi_du_93000
Re: Proxy Alignment error: Radio/Radio Navigation Node Busy error
I have same problem with you. how you solve the problem?
Change the radio?
Change the radio?
