PROXY FIAT 500 WITH CRUISE CONTROL/speed lim.
matte595
Post by matte595 »
please someone who can post PROXY of fiat 500 2016-2020 with cruise control e speed limiter active?
thank you so much
budgoz
Re: PROXY FIAT 500 WITH CRUISE CONTROL/speed lim.
Post by budgoz »
This is from a Fiat 500 with both cruise control and speed limiter as standard:
33 32 31 35 30 30 32 34 36 38 38 4F 55 54 50 55 54 44 4A 49 54 20 16 12 08 4F 80 00 04 02 00 00 00 09 00 00 04 02 00 00 00 C3 C2 73 06 F4 00 1C C0 00 00 00 16 00 01 00 9C 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 01 41 03 00 00 04 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 81 00 0F 00 00 00 00 01 00 40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00
Scealmor
Post by Scealmor »
Thanks for sharing, have been comparing it to the Proxi on my Abarth to see what is common and what is different. I'll.publish it in the coming days. Lots of colour coding. Been reading up on this forum and hoping to decipher the proxi a bit more. Is there s single point of reference for Proxis or is it custom?
matte595
Post by matte595 »
budgoz wrote: 20 Dec 2020, 15:22 This is from a Fiat 500 with both cruise control and speed limiter as standard:
thanks to share
i will try to set the difference in my custom proxy, but not work cruise :( in evidence:
byte 82
byte 88
i hope thath is impossibile will work :(
Scealmor
Post by Scealmor »
Forum Suggestion to change byte 87 to 07 or 09, or 01 or 03. NOT byte 87 it seems for cruise on Abarth.
Suggested Byte 82 to 03 did not work, so (possibly) try bytes 80/81
Byte 80 to 01?
Byte 81 to 41?
Also tried was byte 92 with the different combos. Ruled out as 92 as both green on Fiat 500 w c/c and Abarth. Have undertaken a side by side proxi compare and it's hard to see what is specifically the crusie proxy on the Fiat 500.
Additional info for 7" screen proxi settings.
Will.try to upload some more side do side comparison of proxi
AOC info: Uconnect 7 install and associated byte changes.
Byte 30 change to 10
Byte 38 change to 10 stop mileage flashing
Byte 121 change to 44 Navi+audio
Byte 123 change to D5 Dab radio
Byte 130 change to 05 Abarth logo
Byte 148 change to 05 Uconnect 7
Byte 157 change to 01 carplay
Byte 160 change to 01 android auto
chrener
Post by chrener »
matte595 wrote: 05 Jan 2021, 14:57
thanks to share
byte 82
byte 88
Hi!
What is your BCM part number? etc: 520xxx or 521xxx?
alessandrosx
Post by alessandrosx »
ciao, la funzione dello speed limiter la puoi attivare tramite bite 82 del proxy cambiandolo da 05 per attivare il cruise control, oppure a 07 per attivare il cruise control+speed limiter, ma nota bene che la funzione è supportata dal quadro strumenti con opzione per speed limiter, sul quadro di bordo abarth, la funzione dello speed limite non è supportata, quindi probabilmente non funziona per questo motivo
matte595
Post by matte595 »
dovrei montare un tft datato 2020...
alessandrosx
mi sembra che anche l'ultimo tft fiat 500 anno 2021 non supporta il cruise control
MrBattagliaG
Post by MrBattagliaG »
Avete risolto in qualche modo?
Anyone solve the matter?
I have 595 late 2018 and I have bought the wiper stalk with the cruise lever. Its somehow possibile to retrofit?
I read that there could be some problem with the aft, maybe if I change the byte if tft setting the one of the 500 could work?
