(NIT/NCV) FAILED! - Timeout error
I'm trying to perfom a proxi aligment on my Fiat Bravo 1.6 Easy Multijet. (Not sure if need to choose Fiat 07 or 2014)
Everything works fine except this error: Writing to module: Info-Telematic/Convergence Node (NIT/NCV) FAILED! - Timeout error
I removed the blue&me computer because of battery draining so after remove this ODO start blinking all time. Trying to perfom a proxi aligment to remove the ODO blink.
Any idea about why I'm having this error: Writing to module: Info-Telematic/Convergence Node (NIT/NCV) FAILED! - Timeout error???
Thank you.
Thank you.
Re: (NIT/NCV) FAILED! - Timeout error
As you said Blue&me is removed... This is Convergence Node...
What did you do with proxi? Just alignment or did you try some settings?
Send your configuration and we will see more...
Thanks for your reply.
I followed this tutorial: https://www.youtube.com/watch?v=RD__7upfeaw
Replaced values:
Steering wheel buttons: "Type B, 8 Buttons" to "Type A, 6 buttons, no CTM"
Auxiliary audio input: "Enabled" to "Not enabled"
Audio output: "Stereo audio/CAN tel.mute" to "Mono audio/analog tel.mute"
Blue&me was draining the battery so I removed it. Tried to run the proxi aligment with Blue&me pluged in but I get the same error.
LOG:
CAN CONFIGURATION DATA:
05 00 84 4F 05 00 84 4F 01 00 04 03 00 00 00 01 00 00 00 00
05 00 84 4F 04 00 04 89 05 00 84 4F 04 00 04 89 04 00 04 09
30 34 31 39 38 30 31 34 36 32 30 4F 55 54 50 55 54 2D 4A 49 54 20 14 05 06 4F 84 00 05 89 04 00 04 C1 01 00 07 8F 50 16 00 00 02 84 06 01 28 00 2E C0 81 00 73 00 54 00 00 00 00 00 00 00 00 36 41 05 0C 01 00 00 00 3A 10 28 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Side Acceleration / Yaw Node (NYL)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
18/10/2022 16:26:55
Fiat Bravo 2014 1.6 Multijet 16V
Info-Telematic/Convergence Node (NIT/NCV): -
Side Acceleration / Yaw Node (NYL): Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
FAILED TO EXECUTE
Info-Telematic/Convergence Node (NIT/NCV) FAILED! - Timeout errorRe: (NIT/NCV) FAILED! - Timeout error
disconnect B&M module and do proxi alignment then. choose Bravo '07
B&M module is disconnected. I get the same error even when is connected, looks like B&M computer is broken.
Is there any way to disable/disconnect B&M module from MES before run the proxi alignment??
Hi!
Try this config:
30 34 31 39 38 30 31 34 36 32 30 4F 55 54 50 55 54 2D 4A 49 54 20 14 05 06 4F 84 00 05 09 04 00 04 C1 01 00 07 8F 50 16 00 00 02 84 06 01 28 00 2E C0 81 00 73 00 54 00 00 00 00 00 00 00 00 36 41 05 0C 01 00 00 00 3A 10 28 00 00
Try this config:
How can I change this?
Hi!
Run MES / Body / Proxi / Adjustments
Press Alt+Ctrl+C and save your current setting in to file!
Copy my setting and paste it to tab...
Run proxialignment procedure...
Done, but I'm still getting same error
Executed as Fiat Bravo 2014 1.6 Multijet 16V:
05 00 84 4F 05 00 84 4F 00 00 00 03 00 00 00 01 00 00 00 00
30 34 31 39 38 30 31 34 36 32 30 4F 55 54 50 55 54 2D 4A 49 54 20 14 05 06 4F 84 00 05 89 04 00 04 C1 01 00 07 8F 50 16 00 00 02 84 06 01 28 01 2E C0 81 00 73 00 54 00 00 00 00 00 00 00 00 36 41 05 0C 01 00 00 00 3A 10 28 00 00
08/11/2022 15:17:51
CUSTOM PROXI NEW DATA:
FAILED TO EXECUTE
05 00 84 4F 04 00 04 09 05 00 84 4F 04 00 04 89 04 00 04 09
08/11/2022 15:20:35
Fiat Bravo '07 1.6 Multijet 16V
FAILED TO EXECUTE
Proxi alignment failed, but ODO stop blinking!!!!
Looks like this config worked.
Problem solved, thank you so much!
