500L FROM 2018 CHANGE RADIO, KM BLINKING
tigre
Post by tigre »
hi, im new in this type of car, need help from e expert to help me fix the km blinking
have change module ETM, they are not equal, its possible disable km blinking?
regards
ps: have read this if help
33 31 33 33 30 33 30 34 32 37 30 4F 55 54 50 55 54 2D 53 49 54 20 18 02 22 4F 04 00 05 00 00 80 00 09 04 00 05 00 00 00 00 A7 C7 71 07 85 20 37 00 30 A0 4C 06 00 07 08 8C 03 15 01 28 C2 00 D1 01 35 41 0A 0C 0D 00 80 3E 58 00 02 00 00 32 00 29 03 00 11 1E 00 A0 20 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 00 01 08 0E 00 04 80 10 00 10 80 00 00 47 10 D5 00 11 00 00 49 00 01 14 60 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
abarthmultijet
Re: 500L FROM 2018 CHANGE RADIO, KM BLINKING
Post by abarthmultijet »
What Radio was in the car and what radio is in it now?
tigre
Post by tigre »
hi, have upload photos of units
regards
https://we.tl/t-IAySpCFBil
regards
abarthmultijet
Why did you swap out the radio's? Original broken?
tigre
Post by tigre »
yes, original is no power on
regards
abarthmultijet
Can you try this one?
33 31 33 33 30 33 30 34 32 37 30 4F 55 54 50 55 54 2D 53 49 54 20 18 02 22 4F 04 00 05 00 00 80 00 09 04 00 05 00 00 00 00 A7 C7 71 07 85 20 37 00 30 A0 4C 06 00 07 08 8C 03 15 01 28 C2 00 D1 01 35 41 0A 0C 0D 00 80 3E 58 00 02 00 00 32 00 29 03 00 11 1E 00 A0 20 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 00 01 08 0E 00 04 80 10 00 10 80 00 00 44 10 D5 00 11 00 00 49 00 01 14 60 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tigre
Post by tigre »
hi, i get error to write on IPC - timeout and on ETM - request of out of range
regards
abarthmultijet
This one?:
33 31 33 33 30 33 30 34 32 37 30 4F 55 54 50 55 54 2D 53 49 54 20 18 02 22 4F 04 00 05 00 00 80 00 09 04 00 05 00 00 00 00 A7 C7 71 07 85 20 37 00 30 A0 4C 06 00 07 08 8C 03 15 01 28 C2 00 D1 01 35 41 0A 0C 0D 00 80 3E 58 00 02 00 00 32 00 29 03 00 11 1E 00 A0 20 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9E 00 01 08 0E 00 04 80 10 00 10 80 00 00 44 10 D5 00 11 00 00 49 00 01 14 60 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tigre
Post by tigre »
Hi, have solved, the problem was to the dash,have can problem, was fixed dash and after acepted the code
regards
