2014 500L Uconnect 5 retrofit mileage flashing
Hi can anyone help with the proxi alignment, customer fitted an upgraded radio and get request out of range error
Do I need to change the coding?
Thanks Antony
Thanks Antony
abarthmultijet
Re: 2014 500L Uconnect 5 retrofit mileage flashing
Yes, you need to change the code. Can you upload the proxy?
Hi sorry for the delay it was on my laptop, didn't know you could do that before I checked here, it had a similar radio before but just not nav, thanks Antony
33 31 33 33 30 30 30 32 35 30 39 4F 55 54 50 55 54 2D 53 49 54 20 13 04 03 4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 17 C0 71 07 8F 00 37 10 A1 10 00 0E 00 07 08 84 06 0D 01 3C C0 00 B1 02 35 51 0A 0C 0D 00 00 00 43 00 00 00 00 31 00 31 03 10 11 12 00 67 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 80 12 00 10 00 00 00 44 00 F7 00 00 00 00 00 00 01 00
abarthmultijet
Try to do proxy allignment with the current proxy.
Hi thanks for the reply, already done that about 6 times and just get request out of range
paste Feslog file with error.
CAN CONFIGURATION DATA:
4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 01 04 00 00 10 00 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 09 04 00 05 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
(Multiecuscan 4.8)
30/09/2024 10:59:51
Fiat 500L 0.9 Turbo TwinAir
CAN Setup / PROXI Alignment Procedure (330)
Parking Sensor Node (PAM/NSP): EOL Ok
Airbag Node (NAB/ORC): EOL Ok
Entertainment Telematic Node (ETM): EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Parking Sensor Node (PAM/NSP) SUCCESS!
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
[102A] errors: Byte 123: F7->D5
FAILED TO EXECUTE
(Multiecuscan 4.8)
30/09/2024 10:59:51
FAILED TO EXECUTE
try with disabled DAB - byte 123 change from F7 to F3.
Hi thanks, will that disable the DAB? I think the car has been fitted with a new DAB aerial like original type and fitted with this radio
Also I've seen a few posts about adding 00 more to make it longer, I don't need to do anything like that do I? Also can anything go wrong by doing that or can I always just put back the original?
Thanks Antony
Thanks Antony
take a look at both radios and compare connectors at the back. your current config has navi + DAB enabled. if new radio is missing one or both of those proxi will fail.poxon77 wrote: ↑04 Oct 2024, 07:36 Hi thanks, will that disable the DAB? I think the car has been fitted with a new DAB aerial like original type and fitted with this radio
Thanks Antony
