New Key
Timneelsalfa
Re: New Key
Now many years later. Is adding a new key with mes possible ?
carletes45
Re: New Key
I join the question, can the transponder be reprogrammed with MES in the new versions?
Giulietta 2.0 jtdm Distintive, Exeo 1.8 TSI, Mitsubishi Colt CJ
Re: New Key
If you have a new or virginized key and the pin code for your car, MES can add the new key.
If the key is used before and not virginized or you do not have the pin code, MES will not be able to add the key to your car.
