Jeep Renegade lifti - LED upgrade
majker
Post by majker »
Dears,
I would like to ask about support in proxy - I need to change the oryginal proxy to support LED in Renegade MY2019. The Main lighta works fine. I have the issue with the DRL. Because currently are set bulbs for DRL and I need to change it for orginal MOPAR LED. I connected the wiring in the same way like in orginal Jeeps from factory. Do you know which bytes change the logic of Control for DRL? The ring need 2x12 VDC but in this moment I had one single sięgnął 12/5VDC (this is for DRL bulb light).
If you will have the oryginał proxy from jeep Renegade with factory LED IT will be also important. Thanks.
chrener
Re: Jeep Renegade lifti - LED upgrade
Post by chrener »
124=02
