Hello all,
I upgraded our Fiat 500 1.2 8V from 2019 from a 5'" to UConnect 7" Display. I followed the information provided on the forum, ran a proxy alignment, the odometer do not flash anymore, all commands works fine, except CarPlay doesnt start on the Uconnect 7.
Before i ran the proxy alignment the carplay worked fine, but once I aligned, the Carplay didnt work anymore. The phone when plugged into the car switch to CarPlay, but nothing happen on the U Connect screen, the phone start charging then disconnect.
Byte 148 (UConnect7): 05 only works at 05 (or 45), evenif when i first ran the proxy alignment it said to switch to 5C or 40, but then 'out of range' message, i tried to enlarge from 193 to 235 as some forum said but nothing change.
Byte 157(CarPlay): 01 - i noticed when switch back to 0, the phone starts charging but is not recognized by the UConnect as a media
Byte 160 (Android Auto): 01
My proxy configuration is the following right now:
33 32 31 35 30 30 34 30 30 32 38 4F 55 54 50 55 54 44 4A 49 54 20 18 06
07 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 C2 73 06 F4 00 1C
C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80
2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 47 00 94 00 22 00 04 88 02 00 20 80 00 00
30 00 81 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00
00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00
I'd be taking any help/advice,
Many thanks in advance,
Fiat 5OO (2019) - U Connect 7" Proxy alignment
ninjaturtle003
