I have a registered copy of Multiecuscan.
When I create a template I can see it in the Parameters > Templates menu, I can see all ten templates (0 to 9) and the parameters I've selected. I then select the template I want to use and click OK.
At this point I have no idea visually that my template is loaded, the parameter list is the same no matter which template I select and no parameter is ticked or highlighted in red.
If I create a template with one parameter and then select that template every parameter is visible and none are selected.
Can someone offer some help please?
Using Templates
CheeseMonster
Re: Using Templates
Hi all,
Same as me.
Can create and store the template, but Im not able to use it
BR
Same as me.
BR
