hi, I would like to activate the tsr, traffic sign reconition, there is no option directly on MES, I wanted to know if anyone has a list of bytes to configure, I think the 500x is also fine which is very similar to the jeep.
this option is by default in models after 2019, mine is from 2018 but in many forum say it is also present on previous models.
can someone help me ? Thank you (GRAZIE !! )
jeep renegade byte config for enable TSR
davidino66
Re: jeep renegade byte config for enable TSR
you can try with another configuration software.. MES doesn't have the possibility to do this, other than manually changing the proxy bits, but I don't know what they are..
ciao
ciao
Hi, did you manage to do it?
I read around to change byte 159 to 1100.000 C0 and byte 202 to 0000.00001 01
activated?jaccojavo wrote: ↑07 Feb 2024, 21:16 hi, I would like to activate the tsr, traffic sign reconition, there is no option directly on MES, I wanted to know if anyone has a list of bytes to configure, I think the 500x is also fine which is very similar to the jeep.
