Hello, i've tryed the test mode of the cable, but also if i select different speed of baud rate , always says "timeout". I have only connected the cable to the pc and installed driver. Is possible the cable i bought is a fake?
Must i connect the cable to the car to execute the test in the setting of multiecuscan?
PS my cable work on software scanmaster...
Salve, ho provato a eseguire il test del cavo nelle impostazioni di multiecuscan. Mi da sempre errore di timeout anche se ho selezionato tutti i possibili baud rate di velocita? E' possibile che il mio cavo sia fasullo? con scanmaster funziona....
Io ho collegato il cavo al pc per eseguire il test, dovevo collegarlo anche alla macchina?
in test always timeout
gargamella
Re: in test always timeout
just try to conect your PC/ laptop with cable (VAG COM KKL/ ELM 327) to the car!
than it should work!
gargamella
yes!! it works, thanks, i tought that the test mode was also without connecting the car..
many thanks bye
many thanks bye
Yes you can do that too.
No plugging into the car but in this case you must power up the interface with 12V.
Becasue the intreface it is not powered up by the USB, it need 12V from the car.
