Fiat Bravo 1.9 mjet connected only with engine
Tried to connect fes 2.6 with my Bravo 1.9 mjet 07 and elm 1.4 but the only connection is to the engine ecu (it works)and service reset, but if I try to connect with abs, airbag or to the steering, i receive an error message check the port , connection failed.... I tried also to connect with Stilo 1.9 to deactivate the belts buzzer, it goes to connection but command failed. Tried to move the connector, check all the usb ports and restart the program and with off/on by the car key but without results. I have also noticed testing the proxy alignment that there are some modules that needs elo programming?? Please help me, i would like to buy the complete version of the program but i need it working.....
Re: Fiat Bravo 1.9 mjet connected only with engine
try with new version of FES 2.6.1
I think you need to modify your elm interface. To read abs system you need to connect pin 1. Please see this web page: http://www.multiecuscan.net/SupportedVehiclesList.aspx
Cheers
Cheers
