Programming functions - what is meaning? What can I program?
Alfa 156 JTDm 16V 06.2003
Reset function does not work to board computer
Both odometers are 0.0
If I pay for full version what of described above will be solved?
Reset/Programming functions
alfa147jtdm2008
Re: Reset/Programming functions
Hi, yes i think it's solved in the next release.
What to expect in next releases:
- Revised EDC16 calibration functions
Bye
Bye
It is nice but ... you know what is difference between I think and Yes, it is ?alfa147jtdm2008 wrote:Hi, yes i think it's solved in the next release.
- Revised EDC16 calibration functions![]()
Bye
And what can I program (which function) on the car computer with this program? Would you be more specific ?
Reset/Programming functions means:ARomeo wrote:Programming functions - what is meaning? What can I program?
- reset of self-adaptation parameters
- calibration functions
- programing (injector codes, enable/disable blinkers, disable seat belt alarm, remote controls)
- service reset
- oil indicator reset (for JTDm)
- forced DPF regeneration
On your engine you can do:
You can use the simulation mode to explore all functions in all modules in the free version.
I don't understand what you mean. Body computer of your car is not supported and it does not have reset function.ARomeo wrote:Reset function does not work to board computer
Which odometers show 0 (in which module)?
yani wrote:Reset/Programming functions means:ARomeo wrote:Programming functions - what is meaning? What can I program?
- service reset
My engine is 1.9 JTD 16V M-Jet
not interesting for me, sorry
What about for service interval reset of board computer?
Sorry, I was not enouhgt plainARomeo wrote:Reset function does not work to board computer
The odometers 1 and 2 of engine computer I have mean, not board computer or kolometres-meter.
You can reset service interval on 156 by holding down + and - buttons on the body computer for 10seconds...
You dont need to connect to examiner to do it.
You think I don't know this. It doesn't work on my car!!!TribesMan wrote:You can reset service interval on 156 by holding down + and - buttons on the body computer for 10seconds...
johnboyhgt
In a few cases the reset of service indicator can go faulty.
If you have tried disconnecting the battery and the reset still wont work then you have a faulty speedometer cluster
and the only way to fix is to replace the cluster.
John
John
Picoscope 4223 - Automotive Oscilloscope
Gendan Engine Check Pro - Registered
Fiat Ecu Scan - Registered
Sorry, but what is this - speedometer cluster?johnboyhgt wrote:In a few cases the reset of service indicator can go faulty.
John
