Fiat Panda 1.2 8v - what to buy
Mukker
Post by Mukker »
Hi Gurus
My EPS has been refurbed at BBA Reman.
Unfortunately I need to calibrate the EPS.
I don't have any scanner right now.
Will I be able to do a recalibrate using multiecuscan ?
What cable do I need to buy ?
I have attached a manual/DIY document on how to recalibrate EPS - But it is in German, google translate works OK for me.
Regards,
Mukker - from Denmark
Servolenkung Panda, Gr.Punto.docx
(36.32 KiB) Downloaded 470 times
Fiat Panda 1.2 8v 2006 "Black Label"
Deano
Re: Fiat Panda 1.2 8v - what to buy
Post by Deano »
Mukka if you got your EPS refurbed from BBA reman
it should be calilbrated, I have fitted these units
from them and never had to calibrate them just
fit, plug in, and drive. multiecuscan will do the job
great software to have :D
Regards Deano
Mukker
Post by Mukker »
Correct, it should have been calibrated from BBA Germany.
But it was not. That is why they gave me a manual.
There was some errors on the dash (no hillholder and no ASR) - so I tried to Calibrate it, simply turning the steering wheel (without any connections and without the airbag) until the lights did not show, when turning.
If multiecuscan can do the job, I need a scanner
I have tried to google a little, there seems to be different models.
Which one to pick ?
And thanks for replying.
Teos81
Post by Teos81 »
Mukker wrote:Correct, it should have been calibrated from BBA Germany.
Which one to pick ?
Normally i use a home made kkl interface with the short circuit form pin 7 to 9 (or the 1 adapter) .. some time i also use the ELM interface..
If you only want connect to your eps, buy only the KKL interface is cheaper.. instead if you want to use Fiat ecu scan also for more diag. on your car or other fiat car, buy a ELM327 interface.. if you have some money to spend.. buy a full package with the KKL Cable, ELM327 and the 3 adapter and also a registered version of FES!! :)
If you have other question about EPS ask to me!!! I work a lot with all the fiat EPS.. ;)
Bye bye
Matteo
P.s. Sorry for my bad English...
Registered 2.8.2 Italian user and EPS specialist
Mukker
Post by Mukker »
Hi Matteo
I just bought:
Fully licensed multiecuscan
1 x elm 327 box/cabel
1 x kkl cabel
Now I am just waiting for the hardware to arrive.
Teos81
Post by Teos81 »
Good Buy...
do you also buy the cable adaptor???
If you buy a Chinese ELM clone, and don't work on the can bus ecu, reed the post to see if you can mod it ;)
Bye Bye
Matteo
Mukker
Post by Mukker »
What cable adaptor ???
I bought this
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... SA:DE:1123
Mukker
Post by Mukker »
Arrrrhhhggg.
I need a cable adaptor between the Elmscanner and the OBD2-thing on the car.
Where the wires are connected like the ones shown http://www.multiecuscan.net/SupportedVehiclesList.aspx (Fiat Panda). Something with wire 9
Where do I get the cabel adaptor ?
Teos81
Post by Teos81 »
If you don't want to modify yourself the interface by adding the pin shortcut, you could buy form GEDAM (www.gendan.co.uk)..
Bye
Matteo
Mukker
Post by Mukker »
Hi Matteo
They only ship to adresses in the UK.
I live in DK (Denmark)
I want to buy them finished. I know how long it will take me to modify/make them.
Anywhere else to buy them ?
Regards,
Mikkel
