Alfa 156 remote key programming
I have 156 2.0 JTS Selespeed -04 and it has only one remote key. I do have an extra remote, but I can't install it to the vehicle with FES. This kind of feature would be great.
						Re: Alfa 156 remote key programming
More info: The car has two working keys, but only one has remote buttons. I can remove the key blade and the immobilizator chip from the "dummy" one and use them in the ebay key. So only the remote board has to be programmed.
The remote control unit and the alarm unit can be connected at obd pin 11. I still don't know what ecus these are.
The remote control unit is VAS 97/3.
Can this control unit be found in other model or in Fiat for example?
Still waiting for this feature.Is this even possible? Yani please reply something.
Thanks.
						Thanks.
Seicento
1. Firstly obtain the 4 digit security code for the vehicle
2. Press the button (in the interior light assembly there is a button and an LED next to the alarm ultrasonics) for about a second and the LED will flash.
3. Release the button
4. After approx 5 seconds the LED will flash once
5. Enter the first digit of the security code using the button as above.
6. Wait for about 5 seconds and the LED will flash once. Enter the second digit of the security code as above- if one of the digits is a zero, do not press the button at all and wait for the single flash requesting the next digit.
7. If all the numbers are entered correctly the LED will flash for 10 seconds Whilst the LED is flashing, press and hold the button near the interior light (used above) The LED will continue to flash until you press a button of a remote- it will then remain on.
8. Release button of remote and the one in the interior light.
9. Repeat for subsequent remotes
Cinquecento
7. Enter the second digit of the security code as above- if one of the digits is a zero, do not press the button at all and wait for the single flash requesting the next digit.
8. If all the numbers are entered correctly the LED will flash for 10 seconds whilst the LED is flashing, press and hold the button near the interior light (used above)
9. The LED will continue to flash until you press a button of a remote- it will then remain on.
10. Release button of remote and the one in the interior light.
Bravo/Brava
5. Enter the first digit of the security code using the button as above. Wait for about 5 seconds and the LED will flash once
6. Enter the second digit of the security code as above- if one of the digits is a zero, do not press the button at all and wait for the single flash requesting the next digit.
7. If all the numbers are entered correctly the LED will flash for 10 seconds whilst the LED is flashing, press and hold the right hand button near the interior light (used above)
8. The LED will continue to flash until you press a button of a remote- it will then remain on.
9. Release button of remote and the one in the interior light.
Coupe/Barchetta
2. Press button (in the interior light assembly there is a button and an LED next to the alarm ultrasonics) for about a second and the LED will flash.
8. If all the numbers are entered correctly the LED will flash for 10 seconds whilst the LED is flashing, press and hold the right hand button near the interior light (used above)
Ulyssee
New remotes cannot be programmed without the use of diagnostic equipment but existing remotes can be synchronised as follows:
1. Switch on the ignition
2. Press the lock or unlock button and hold for 10 seconds.
Scudo
2. Wait for the system LED to extinguish
3. Press the lock or unlock button and hold for 10 seconds, do this on all remotes to synchronise them.
Cinquecento
Bravo/Brava
Coupe/Barchetta
Ulyssee
Scudo
Still waiting. No immobilizer programming needed when using old chip.
Some software can program the rc (googled) and they will ask password code while programming is done. Is this code same that immobilizer has?
				159sportwagon
hello, i have a punto 188 1,2 16v. i buy a new key but i can not programming with fes . anybody  have an idea ???
