Multiecuscan 3.0 released!
I just released multiecuscan 3.0.2 to fix the problem with data language changing to English on its own.
I just released multiecuscan 3.0.1 to fix some licensing problems.
I released Multiecuscan 3.0 today.
There are some major changes in this version and I decided to make it 3.0.
One of the big changes is that I started adding modules without full support - It is much easier (and faster) to add reading of module Info and error codes than to add all functionality (like Info, DTC, Parameters, Actuators, Adjustments). So, I decided to include error reading coverage for many modules (inluding almost all types of air condition modules) first, and then add the rest of the functionality.
The changes are:
- Improved connection stability with VagCom/KKL interfaces
- Added "Test" function for VagCom/KKL interfaces which reports the interface latency. Also added a setting to which improves the communication stability with high latency VagCom/KKL interfaces.
- Improved support for 800x600 screens
- Added graph scrolling with left/right arrow keys
- Improved graph precission and added setting to control redraw frequency
- Added function to display miles instead of kilometers
- Fixed the problem with high memory usage and slow loading on Windows 7 x64
- Improved vehicle scan function
- Improved interface message before connection. It now displays the required pin/switch and properly identifies which vehicles require 3-pin adapter.
- Added Portuguese(BR) data language
- Added more PROXI configuration options
- Support for Bosch Motronic Me7.6.3 CF4/EOBD Injection (Panda '06 1.4 16V)
- Support for Bosch EDC16C39 CF5/EOBD Diesel Injection (Grande Punto/Punto Evo/Doblo/Mito 1.6MJET/2.0MJET)
- Support for Autoliv MY99 Airbag
- Support for Delphi climate control (Info and DTC only)
- Support for Marelli climate control (Info and DTC only)
- Support for Borletti/Hella climate control (Info and DTC only)
- Support for Denso climate control (Info and DTC only)
- Support for Valeo climate control (Info and DTC only)
- Support for BOSCH Airbag 2 (Doblo) (Info and DTC only)
- Support for TRW Airbag (Ducato) (Info and DTC only)
- Support for Marelli/Finmek Body Computer (Ypsilon) (Info and DTC only)
- Support for Marelli Body Computer MY03 (Punto '03/Doblo) (Info and DTC only)
- Support for Marelli Body Computer (Idea/Musa/Palio) (Info and DTC only)
- Support for Marelli Body Computer (Linea/Idea/Brera/Musa/Ypsilon) (Info and DTC only)
- Support for Bosch ABS 8 ESP (500/Grande Punto/Punto Evo/Mito) (Info and DTC only)
- Support for Continental MK60EC ABS (Doblo) (Info and DTC only)
- Support for Bosch MSA 11 Diesel Injection (2.4) (Marea 2.4TD/K 2.4 TD) (Info and DTC only)
- Support for Bosch Motronic M1.7 Injection (155/164/Thema/Croma) (Info and DTC only)
- Support for Magneti Marelli IAW 4SF Injection (Linea/Palio, 1.4 8V/1.8 8V/1.9 16V/1.0 8V) (Info and DTC only)
- Support for Magneti Marelli IAW 5SF CF4/EOBD Injection (Linea/Idea/Doblo/Ypsilon/Musa 1.4 8V/1.2 8V) (Info and DTC only)
- Support for Magneti Marelli IAW 5SF3 CF4/EOBD Injection (Grande Punto, 1.2 8V/1.4 8V) (Info and DTC only)
- Support for Magneti Marelli IAW 4SFG Injection (Palio 1.4 8V) (Info and DTC only)
- Support for Magneti Marelli IAW 5SF4 Natural Power Injection (Ducato 3.0 16V) (Info and DTC only)
- Support for Magneti Marelli IAW 5SF8 CF5/EOBD Injection (Panda 1.2 8V) (Info and DTC only)
- Support for Bosch Motronic MeD7.6.1 CF4/EOBD Injection (159/Brera 1.9JTS/2.2JTS) (Info and DTC only)
- Support for Bosch Motronic MeD7.6.2 CF4/EOBD Injection (159/Brera 3.2V6) (Info and DTC only)
- Support for Bosch Motronic Me7.9.10 CF5/EOBD Injection (Bravo/Linea/Delta/Musa 1.4 16V) (Info and DTC only)
- Support for Bosch Motronic MeD17.3.1 CF5/EOBD Injection (159/Brera/Delta 1.8JTS) (Info and DTC only)
- Support for Magneti Marelli IAW 5SF8 CF5/EOBD Injection (500/Grande Punto/Punto Evo 1.2 8V/1.4 8V) (Info and DTC only)
- Support for Magneti Marelli IAW 5SF9 CF5/EOBD Injection (500/ Punto Evo 1.2 8V/1.4 8V) (Info and DTC only)
- Support for Magneti Marelli IAW 5SF8 Natural Power Injection (Grande Punto/Punto Evo 1.4 8V) (Info and DTC only)
- Support for Magneti Marelli IAW 8GMF CF5/EOBD Injection (Punto Evo/Mito 1.4 16V) (Info and DTC only)
- Support for Magneti Marelli IAW 5AF GAS Injection (Panda/Punto BiPower) (Info and DTC only)
- Support for Magneti Marelli IAW 4AF/4EF GAS Injection (Multipla/Doblo BiPower) (Info and DTC only)
The changes are:
radu_gostian
- Contact:
Re: Multiecuscan 3.0 released!
Great Work !
That's why the site was down
By the way after you install it, the exe name is still multiecuscan2.exe
no pain, no gain
Great JOB ...!!
thnx
thnx
Do not forget - EOBD pin 9 is for Alfa climatic diagnoses!!!
wow!
great major release
i'll wait some days just to let everyone test it out
then i'll update
great major release
piscinarasx
the license: I had the 2.8.2 to 3.0 is not good what should I do? thanks
Donwload and install Multiecuscan 3.0.1.piscinarasx wrote:the license: I had the 2.8.2 to 3.0 is not good what should I do? thanks
piscinarasx
still does not work.
works - pin 9, not pin 7piscinarasx wrote:still does not work.
dallas140cv
Great work, Yani! On the supported vehicles table, there are this vehicles to verificate as 3-pin adapter: GTV/Spider 1.8 TS and 2.0 TS cee F2 (MY98, but not indicated as MY98 and no cee F3) and MY98 Fiat Multipla.... If I don't have a mistake, they don't have the EOBD connector.
