Does Multiecuscan work on Iveco
Hi there Just wanted to know if Multiecuscan works with Iveco Daily and Euro Cargo
Re: Does Multiecuscan work on Iveco
I don't know but try to check out the type of ecu installed, search if the same ecu is supported in FES then maybe...maybe...it could work.
I agree with EnIgMa...EnIgMa wrote:I don't know but try to check out the type of ecu installed, search if the same ecu is supported in FES then maybe...maybe...it could work.
Uveco Daily and EuroCargos ECU's:
Powertrain:
-Bosch EDC16C39 Iveco
-Bosch EDC16C9 Iveco
-Bosch EDC7 Iveco
-Bosch MS6.2 Iveco
-Bosch MS6.3 Iveco
Chassis:
-Bosch ESP 8.0 Iveco
Powertrain:
-Bosch EDC7 Iveco
-Bosch MS6.2 Iveco
-Bosch MS6.3 Iveco
Chassis:
Thank you guys for the info I will try and let you know.
