What causes low Actual Air Intake Quantity on 115JTD
Re: What causes low Actual Air Intake Quantity on 115JTD
you can see if you have a problem with this only in graphical menu
SillyBilly
Not sure what you mean. I posted a link to the traces from the graphical part a couple of posts ago
You have to be with 0 281 002 309 air mass sensor. The real sensor inside is HFM-5-4.7 - this sensor is like a sensor of most air mass meters (only the body is different) like a 0 281 002 309 which is two times cheaper than .... 309. Open your air mass sensor and see if the real sensor is HFM-5-4.7. If it is not - the problem is clear
