Bought a 1.4 ELM cable which allows me to connect to the Bosch ECU with no problems. Have borrowed an ELM 1 adaptor and with that I can get to ABS, however I can't connect to any other ECU's. Body dash etc etc. Scan just returns the 2 mentionned before.
Am I missing something obvious as the 'supported vehicles list' suggests I should be able to connect to the lot with just the std ELM cable.
I just see the no connection ELM to ECU error.
2006 2.4 JTDM
Ta
Karl
Alfa 159, can only see engine and ABS
Re: Alfa 159, can only see engine and ABS
Maybe there is something wrong with your ELM 327 1.4 interface?!?!?
Try to go here:
Board index ‹ Usage Q&A ‹ FAULTY ELM 327 INTERFACES DE-MYSTIFIED (READ HERE)
Maybe you can find solution there...
Try to go here:
