Various OBD II VAG COM KKL cables
Re: Various OBD II VAG COM KKL cables
This can be used, as well as many other KKL
greetings Eddy
greetings Eddy
you mean, it can be used for Alfa/Fiat/Lancia right?Alfaeddy wrote:Hello
greetings Eddy
The ones listed as "KL" in the supported vehicles list, yes.amiko wrote:you mean, it can be used for Alfa/Fiat/Lancia right?Alfaeddy wrote:Hello
greetings Eddy
greetings Eddy
Right
Looks OK! But it is too expensive...amiko wrote:What do you think about this cable:
http://cgi.ebay.com/VAG-COM-KKL-409-1-O ... _802wt_698
Depends what you're after really.alfa156sarajevo wrote: Looks OK! But it is too expensive...![]()
I've used a £5 cable and a £20 cable, and you can feel which one's going to last longer before you even connect to car.
The very cheap cables are cheap for a reason - they're built down to a price.
hi,
can i use this cables in bravo TD100?
thanks
thanks
I think you can use VAG COM KKL USB interface for your Fiat Bravo TD100.azulou wrote:hi,
thanks
You will also need an 3pin adapter!
Before you buy anything just check your vehicle on this list: http://www.multiecuscan.net/SupportedVehiclesList.aspx
Cheers
