now.. is this true? I thought I could use ELM device for all the ECU functions with FEC? is there a different method? My cable can connect to anything else on the car, Body, ABS, Engine, Gearbox, etc. but Airbag is a no no
Airbag Connection problem
Hi guys.. I have a Alfa 147 with the airbag light permanently on, I want to connect using FEC and my ELM327, but when hitting connect I get a direct message saying you need K-Line or Vag-com for this function.
Re: Airbag Connection problem
Yes, it's true. From the supported vehicles list:
No mention of ELM there.SIEMENS MY99 Airbag (2F-2P-2L-2T-I) |INFO|DTC|PRM|ACT| KL 3 OBDKey 3 A2
thanks.. where did you get that from? I want to see that list and see what else I can find..
wonder why they then say you need ELM OR vag com OR obdkey
http://www.multiecuscan.net/SupportedVehiclesList.aspxgerryd wrote:thanks.. where did you get that from? I want to see that list and see what else I can find..
Some modules can be accessed with both the ELM and the KKL, others require specific features of one lead that are not supported by the other.
From memory the OBDKey interface supports everything, but it's more expensive than buying an ELM and a KKL, so swings and roundabouts...
thanks bro, now I am off to get me a damn vag com as well.. already have the ELM.
