ADAPTION DRL LED FROM ABARTH 500 C MK1 (PREFACELIFT) TO MK2 (FACELIFT)
Hello everyone, I have a 2013 Abarth 500 c pre-facelift to which I have adapted the facelift LED DRL lights. The electrical diagram is the same in both models, except that in the facelift version the DRL ring is LED and logically in my Abarth I get the parking lights error as soon as I turn on the lights and the DRL ring lights up. Does anyone know what byte number needs to be modified in the custom proxy so that this error does not appear? Is there any publication about DRL adaptation in a Fiat Ducato X290 but I don't know if it will be the same. Thanks
Re: ADAPTION DRL LED FROM ABARTH 500 C MK1 (PREFACELIFT) TO MK2 (FACELIFT)
If it is not possible, someone who knows could provide me with the proxy configuration of an Abarth or Fiat 500 with the LED DRL lights to compare it with mine and see the differences and be able to publish a solution. thank you
I'll answer myself. I got a BCM from 2019 and cloned it. Even so, the pins on the BCM must be modified to update the line and change byte 73 to 2E. With this, the DRL line works perfectly without the need for resistors.
Hello. Can you tell me which pins need to be changed?
