First time using this software so may be an issues with my process but would appercaite some guidance.
Attmept to get ECU but reciveing message error measge on being unable to connect.
I have multiscan downloaded on PC with Windows 11. No where to check but assume its all updated. I'm using Multiecuscan 5.3 REGISTERED.
KKL K Line Used
Direct to OBD Port
Red Light on the KKL
Ing on
Com port selcted by scan for interface and chekcing device mangagr. Com3 in my case with K-line selcted.
Hit Connect
Unable to connect to ECU.
Checked requirments for my vehlce is as follows, which I have all correct I assme. Which is below copied from here https://www.multiecuscan.net/VehicleSupportCheck.aspx
Engine management
Bosch EDC15C7 CF3 Diesel Injection (2.0, 2.3, 2.8)
Supported functionality:
Read identification details, Read/clear error codes, Read error code details, Read up to 89 live data parameters, Execute up to 18 actuators/tests, Execute up to 7 special functions and procedures
Possible to connect with following interfaces/adapters:
KKL (for interfaces with pin-switch - set to 7)
Still have made no progress so would apprecaite any help with this,
Sam
						Unable to Connect Fiat Ducato 2005 244 EDC15C7
Re: Unable to Connect Fiat Ducato 2005 244 EDC15C7
Push this back up to see if a user can assit?
