I was happily surprised to hear about Multiecuscan. I own a Fiat Barchetta from 08/1995 which has the first Hitachi ECU version. As I understand it, there is partly support for 2nd version and full support for third version. I have bought a K-Line cable and a Fiat adaptor for the 3-pin Fiat service connector. However - I get absolutely no connection to the Hitachi ECU.
Before I give up totally, I would like to know, if you plan in some foreseable future to support also the old Hitachi ECU. If yes, when would you expect it to be supported. I would gladly pay for the prof. version if the support for my old Barchetta would only be included here.
Thanks in advance
- and keep up the good work!! You make a lot of Fiat people very happy.
regards, Peter
Support version 1 Hitachi ECU - Fiat Barchetta
Re: Support version 1 Hitachi ECU - Fiat Barchetta
Hi Yani,
I'm sure you are very busy, but if you could just indicate if and when you plan to support the early versions of Hitachi ECU
Thanks in advance
Thanks in advance
The same situation with Fiat Brava and Hitachi ECU. Is there a chance to have support of these ECUs?
Regards
Regards
One more vote for support hitachi mpi ecu.
I have Fiat Brava 1.8 16v 1996 with hitachi ecu and it will be great if you can make support for this.
I think that with this support more people will be satisfied after me .
Best regard
Best regard
hitman142006
Same thing here with a 1996 Fiat Coupe 1.8 16V with a Hitachi MFI-018.
If i see good,in fiat ecu scan 2.7 hitachi mpi is suported?
Great job,man!
Can someone just verify that all I need for conecting to my Brava 1.8 16v is Fiat Ecu scan,elm 327 and 3 pin to obd adapter?
One more time,thanks!
Great job,man!
