Solved: 2014 facelift 2.3l ducato tank resize
scoobyooby
Post by scoobyooby »
Would it be possible for someone to aid me in resizing the tank please?
Ive tried with byte 60 and 67 but I'm probably doing something wrong. byte 67 has something to do with an airbag module and luckily I didnt set it to a correct range, it spit an error.
Ive purchased a new tank pump and tank for my ducato. Old tank was @70l and had the short-body pump.
New tank is the 125l variation and has the long-body tank pump with no limiter.
Solved: I figured out that there may only be two pump sizes, and there may be 4 or so models for the ecu to calculate from.
Essentially from what i can gather, either your ecu has the option to change the fuel tank size in which case modding with MES should be quite straight forward.
In my case, I modded byte 60 from 02 to 03. the fuel level now reads a logical amount. So I assume byte 60 is just telling the ecu which pump to expect and deal with the ohm curve accordingly.
Now the dash cluster can learn new percentages to fuel usage and distance traveled and , given time will learn the new range.
byte 91 should be changed to "3"0 .
Unfortunately these changes are not permanent and are not permanently written even after running proxy alignment.
Re: Solved: 2014 facelift 2.3l ducato tank resize
check also byte #91 bits 4-7. looks like it should take same value for tank. if #60 is 03 then #91 should be 3X
scoobyooby
So byte 90 or 91 are range values?
scoobyooby wrote: 22 Sep 2025, 12:29 So byte 90 or 91 are range values?
sorry, typing mistake - byte 91. not sure if it will change anything or will any have effect.
scoobyooby
Why then touch byte 91? Chatgpt thinks it's a fallback byte...but as we all well know, chatgpt talks out for its ass.
I guess one way to figure it out would be to use alfaobd...their options list has way more settings even if the program itself is less useful.
scoobyooby
so after running with a modified byte 90, my vehicle is showing 27l/100km which is very wrong.
so Byte 90s first number is multiplying the vehicles true consumption by 3, which is what I changed it to.
