Hello all, I purchased MES from Gendan last year, only just activated it a couple of months ago (as I didn't really have the time to use it , or actually need it)
So I connected it to the car today for the first time (a 2022 Abarth 595) using the yellow adaptor (because at one stage it specifically asked for the yellow one)
I selected Fiat 500 1.4 Turbo 16V T-Jet/MultiAir Abarth
On the first scan MES first of all stopped with a banner saying "Invalid ISO code 'ISO identified as Body Computer Delphi 500c - Y to continue" ???
Is that indicative of needing a proxi alignment ? (I didn't want to even attempt that until I'd consulted )
It also appeared that there were only a few modules available to access (but being new to it I'm not 100% sure what is supposed to be available on this car)
Note: There is nothing wrong with the car in normal use, no flashing dash, etc... but it has also spotted a U0019-88 B CAn line problem (but not a constant fault so it just says check into it or something similar)
I have also spotted (in the proxo section I think) "Side acceleration / YAW node (NYL) "Removed" (in red) ??
I did do a reset/clear codes , and I thought I'd re-visit it in a few days when I had got some feedback
