SET TIME AND DATE CROMA
ilgeometro
Post by ilgeometro »
Good morning Yani, I need your help, please!!I make a question.
I have removed the original connect nav from fiat croma (made 2005) and to set time and date that occured! With the software FIAT ECUSCAN can I anyway to modify and to set the time and the date? If it's possible, how it? where are the commands and functions for this?
Thank you for disponibility.
good job :? :(
Re: SET TIME AND DATE CROMA
Have you tried setting the Date and Time on the Menu/Mode Button on the dashboard? (next to the lights buttons)
ilgeometro
Hi s130! Oh, yes i do it but without positive response because perhaps olny works means the original connect nav.Then if I remove the original connect nav I believe that it's impossible to set the time and the date directly from the menu button car. Perhaps it's possible do it with software FIAT ECUSCAN? Help me please!? :( :( :?:
Thank you and good job
No, it is not possible to set date and time using Multiecuscan.
ilgeometro
Hi Yani and Thank you! Please, do you know another mode to modify the time and the date?
Good morning.
Bye
Davren
Post by Davren »
For vehicles that have had a Connect Nav+ unit removed, you can set the time by disconnecting the battery for a few minutes and then reconnecting it exactly at midnight. This will start the clock at 00:00.
Unfortunately, you will loose any stored trip data by disconnecting the battery.
