guys I have a big problem!
yesterday everything worked when I wanted to connect with the driver of the car. Today I changed my laptop to another but weaker performance is ok (1.7 ghz processor and 1.5 GB RAM memory)
I wanted to connect to my Fiat Brava (I've done it many times with success). I connected everything as always.
The only mistake I made haste to me is that the power cord from the ground (-) touched the clamp from the battery positive (+) for a split second, clicked a little bit. Then I plugged everything correctly, the red light in the KKL vag is lit normally.
Only at this point the problems begin with the connection of all engine ECU does not respond, ABS ECU is not responding ....
now anyway. I also tried it ELM327 1.4 to connect to the engine and it's the same messages? my friend gave me his ELM 327 1.3 + and have nothing you can not do.
The question of whether there is something wrong in the laptop (yesterday to connect without a problem). Do burned interface, or 3 pin adapter cable. Why is that I have 4 versions of FES on the same hard disk 2.6, 2.6.1, 2.7, 2.7.1 but in the previous laptop had the same and acted.
I installed the interface on port com1. How to turn scan 2.7 interfaces in the FES is to write that he found on the interface is COM PORT 3?
Strange .... I change positions on the computer com port 3 interface is then again when he writes that there is no interface
interface is, of course, is connected to the same USB port in which it was installed
any ideas ?????? please help
