I released a new version today. The main improvemets are:
- Added Magneti Marelli IAW 4AF/4EF/59F/5AF support
- Added Magneti Marelli IAW 49F support (Experimental release. Testers needed)
- Added EDC15 support for 2.0, 2.3, 2.8 engines
- Rebuild user interface. All functions are accessible through keyboard shortcuts.
- Added interface latency detection.
- Improved communication protocol, more stable connection.
Multiecuscan 1.3 RELEASED!
Re: Multiecuscan 1.3 RELEASED!
Thank you of course will be able to scan Lucas EPIC doblo 1.9d?yani wrote:Hi,
when connected me to write :: Serial Port latency Too Hight..... ???
is probably something wrong in my settings???
buffer is the minimum........
Kecka,
If everything is ok with the serial ports then your computer is probably too slow for the program. Showing parameters and drawing graph is taking lots of system resources.
What is your CPU?
What is your CPU?
my computer is a Dell C600 CPU 700MHz RAM 384 Mb ...........
Programs VAG, Galleto,and others........ work well
Hi Kecka,
yes, your laptop is indeed very slow to use the program.
I'll make some optimizations on the future versions to make the program work on slower computers.
What are the minimum requirements for the computer ????,
The oldest laptop that I have for testing is with 1GHz PIII CPU. The program works almost fine on it - It shows the latency message but does not disconnect when reading parameters.
Anyway, I know why the program is using so much CPU resources. I just did not care about it because on my working laptop (which is almos 1.5 years old) there is no problem with the CPU performance.
I will definitely spend some time on improving the performance before next release.
Hi! 2000 Fiat Punto 1.2 16v Bosch ME 7.3H4 benzine test and only 99 fiat punto 1.2 8v do you know but out writes as no good protokoll y continue n closed,whwt answer? sorry engish
Bisch 7.3 is not supported yet.
Do not try to connect to your car with different selection.
