Hi all, im a proud owner of a Fiat Evo 1.2 of 2011.
I normally use Android Torque whit a BT ELM and it works perfectly, after discovering this web site i found that im not actually connected to the main system but to the Delphi Electric Steering (because of the elm / elm c19), so i suppose thats why torque cant get Maf sensors and others.
So i download FES and try out, made some custom switch on the elm so i can change from standard to C19 on the fly.
But the only thing free that i can access is the "Can Info" all other modules are show Red but say connections successful.
Can i see any parameter/value on my car using free FES other than CAN Info? The Free/Pay function list show parameter,actuators, graphs for the free version but in the end, Punto Evo can only access Can Info, not really helpful to captivate to buy the Full program.
Any way my Evo can single press Open the all Windows, but only close the Drivers window, the passenger must keep pressing until fully close, can FES help whit this? also, more expensive evo models can open/close windows whit the remote, can FES also help?
I can only see CAN Info on Evo, need advice about funtions
Re: I can only see CAN Info on Evo, need advice about funtio
On the Supported Vehicles List, all control modules and procedures apart from CAN info are listed in red type, which indicates they are only available with the registered version of the software.
Juggers2k is right!
You need registration key to read all other systems in your EVO!
All other mean 99% of them
Any way what about my wishes of turning on the automatic windows? can FES enable them?
Are you really complaining that the FREE software doesn't do as much as you want it to?Ikari-Pt wrote:All other mean 99% of them![]()
I would prefer a evaluation version instead a free one, because in the case of my car the table of free funtions is more like this:
Free / My car
Clear fault codes Yes/No
Read diagnostic data Yes/no
Actuator tests Yes/No
Display data in graph Yes/No
This means that i cant test if the program works as i would like and eventually buy the full version.
Free / My car
