The important function for me is the Service Reset and the Service Reset for Oil Change.
This function is new in version 3.2 and so I was happy to use it, but it want not work at first.
The problem was, that I got the failure notice “False ISO Code” when I use the function.
But I can ignore that and then I can change the the most values. So also the values for normal Service Reset.
The problem is futhermore that the oil lamp is blinking after starting the motor and the display shows: Oil Change.
Now I found, that this is a special problem of my car with the Diesel Particular Filter (DPF). There must be a special reset and this is not included at the moment in Version 3.2.
Now I found the solution:
The reset of the oil change warning for my Ducato 3.0 with DPF can be made with the selection Fiat Croma ’05 2.4 MJET 20V. You must ignore the notice “False ISO Code”. Then must be selected: Engine. After pressing F7 there is the first point the reset of Oil change for DPF cars.
