Glad to upgrade FES to 3.2 version, because there are more options for climate control unit. But I'm not able to do actuator tests. I received message 'test failed'. What I'm doing wrong? I can see all parameters. I tried with climate control ON and OFF, but without success. This is on my Alfa 156 JTD'02.
Climate control unit - actuator tests
Re: Climate control unit - actuator tests
This is bug but Yani still be in silencemontezumijus wrote:Hi,
I was on a long vacation and now I have lots of emails, PMs and threads to reply to...
Yes, I know about the problem with climate control actuator tests and will try to fix it for the next release.
Ok, we are waiting
Hi Yani,yani wrote:I was on a long vacation and now I have lots of emails, PMs and threads to reply to...
Have you solved this problem in v3.3?
Hi Jani,
Do you plan to fix bug with climate control actuator test? I have registered 3.4.1 FES version. During connection to climate control module I get this: 'WARNING: Invalid ISO code for selected vehicle system!' When I try to makes some actuator test I receive this: 'FAILED TO EXECUTE". I also have sent you report (2012 02 25 3:02 PM). I hope you won't ignore this message.
