alfa 159 immobilizer
159sportwagon
hello yani, a few weeks ago i try to flah my ecu for chiptuning. and now the engine will not start.in my dashborad is the sign for the immobilzer. its possible to release this in the next version of fes.best regards
Re: alfa 159 immobilizer
Yes! It would be nice!
LOL... there is nothing wrong with the immobilizer.
Your checksum is not OK, that is the problem
Flash back the original file.
159sportwagon
Hello I try to flash back the original file. But it's failed . I have no ideas , what I can do .
hello 159sportwagon,
right now I am working on the solution for your specific problem. but I need you original file to test it.
please send me here as PM or over facebook - you know me.
tomsa
tomsa
http://tomsa.bplaced.net
Which tool do you use for flashing the ECU?159sportwagon wrote:Hello I try to flash back the original file. But it's failed . I have no ideas , what I can do .
159sportwagon
hello, i flash my ecu with mpps flasher. today i was at the fiat shop. the mechanic try to read my alfa 159 with the examiner and he says that the bodycomputer has no communication with the ecu.he mean my ecu is damaged. regards
If the MPPS is older than v5 then it will f++ck up the ECU while writing checksum. But most of the time you can still write the original file back.
But I guess in your case you must have had some problems during writing, an error that didn't complete the flash successfully.
So the only solution now is to go to someone who has BDM, let him read your ECU, give him your original file that you read with MPPS, and he will be able to reconstruct the files toghther. Then he will write them to the ECU with BDM.
I think that is the solution for you. Dont go buying new ECU until you will try that.
You can also buy a simple clone BDM100 for 50€ and do it yourself, if you think you are skilled enough.
159sportwagon
hello,I know someone who can restore the ecu.i send him and he says he can made it.many thanks for this info for the v.5 version. i look ,what for a version is my mpps.do you knoe the digiflasher.http://www.my-obd.de/Chiptuning/Digifla ... w::15.html. regards
No, never heard of digiflasher...
MPPS is quite reliable on those ECUs, if you have you computer set up properly and you use v5.
I have flashed at least 50 times on that ECUs without problems.
