Hello Yani.
My standard (1.6) cluster died recently, and I have purchased a used Stilo Abarth cluster. I was very happy to find that the speed and rev counter worked perfectly, because I was wondering about the postitions of the markings on the dials that differed. But somehow the BC or the cluster calculates this. After clearing stored faults I did a Proxy Alignemt, but it crashed when writing to the Climate ECU. Everything seems to work though, no more reverse sensor fault or loose connection. I have also gained access to options in the "Menu" button which didn't work at all before the PA.
Milage has now stopped flashing, but at a lower value than origial. Is the other value stored somewhere else? It differs from 98.000 km to 87.000 km so not much.
Any ideas about the Climate ECU problem during the PA?
Regards, MW.
Proxy Alignment Fiat Stilo / Fail on Climate ECU
Alfa Romeo GT 3.2. Ex: Ritmo Abarth 130TC. Ex: Uno 1.1 ieS. Ex: Stilo 1.6.
fiatbravoemotion
Re: Proxy Alignment Fiat Stilo / Fail on Climate ECU
Try use another ELM327 to do Proxi.Jojjo wrote:
Any ideas about the Climate ECU problem during the PA?.
It's the Gendan bundle and should be a good choice. I've tried other cheap ELMs but they were a waste of money.
Hey mate
I saw that you think that you'll waiste your money on Gedan all will be great.
Your cheap ELM327 it is version 1.3 or higher?
If yes and you connect with it on k-lines controls and on CAN controlers that it is all right.
And the interface it's doing its job.
Now try to think why you couldn't do the proxy Alignment in good condition?
There is a problem with PROXI alignment of Climate control on some Stilos. In your case this is not a problem because your climate control is ok and does not need PROXI alignment.
The fact that mileage is not flashing anymore is an indication that everything is ok on your car.
In the next version I've made some more improvements to the PROXI procedure and hope that it will work on the climate control module in Stilo.
As I've written many times before ... The PROXI function does not correct the mileage. You can change the mileage by using the appropriate adjustment function when you connect to the dahsboard. However, please have in mind that the mileage value can only be INCREASED!
