hi,
I have an registred copy of Multiecuscan 3.3 and when launching find ecu (F11), the ESP going to disabled.
I have a freemont mjet 140 cv.
I also tried the adapter n° 3, always using lm327 v.1.4.  I'm doing well?
Regards,
Paolo G.
						ESP function will be disabled when i find ecu
Re: ESP function will be disabled when i find ecu
You shouldn't need any adaptor cables when you are running the module scan.
The Freemont isn't listed as supported yet though, so you may not find any coverage.
With regards to systems being disabled while they are scanned, this is normal I think.
On my GPunto when the system is scanning the ABS, the dashboard brings up a warning that it's disabled. When the scan finishes it's enabled again.
ok, i tried without any adaptor, but don't find anyting, maybe that's like you said.
then wait for the new version
Thanks for your reply
Paolo G.
Paolo G.
It's normal when You try to connect with ESP/ASR/ABS and EPS ECUs, the ECU goes to service mode.xpau wrote: when launching find ecu (F11), the ESP going to disabled.
I suppose that in Freemount is high speed can, You can only connect with correct adapter type.xpau wrote: ok, i tried without any adaptor, but don't find anyting, maybe that's like you said.
BAS
which adapter type i can use ? LM327 v.1.4 is not good for high speed can ?bas wrote:It's normal when You try to connect with ESP/ASR/ABS and EPS ECUs, the ECU goes to service mode.xpau wrote: when launching find ecu (F11), the ESP going to disabled.
BAS
thanks for your reply
Paolo
Wait till FES will support Freemount.xpau wrote:which adapter type i can use ? LM327 v.1.4 is not good for high speed can ?
Paolo
BAS
