I released Multiecuscan 3.4...
..and also released Multiecuscan 3.4.1 (which should fix the crashing of Multiecuscan on some computers)
I released Multiecuscan 3.4.2 to fix PROXI problems with Stilo, Grande Punto, Evo and Mito. It should also fix the connection problems which some users had with previous release
The changes are:
- Released Multiecuscan MULTIPLEXED version with special multiplexing interface and license locked to the interface
- Released FES mobile 2.0 with full support for same cars/modules/functions as Multiecuscan (except Adjustments)
- Added support for FIAT ALBEA and ALFA SPIDER '06
- Improved support for ELM 327 and OBDKey interfaces
- Added full support for OBDLink interfaces
- Fixed actuators/adjustments execution problems on many ECUs
- Fixed "alarm mode" and "blinkers on/off" functions on Grande Punto and Mito
- Fixed "Logistic Mode ON/OFF" function on many models
- Added "Abort" function while executing actuators/adjustments
- Added SCAN DTCs function (works the same way as the SCAN function but checks each module for error codes)
- Added more PROXI Configuration options and improved PROXI function
- Support for Bosch Motronic MeD7.6.2 CF4/EOBD Injection (159/Brera 3.2V6) (Full support)
- Support for Magneti Marelli IAW 8GMF CF5/EOBD Injection (Punto Evo/Mito 1.4 16V) (Full support)
- Support for Bosch Motronic MeD17.3.1 CF5/EOBD Injection (Giulietta) (Info and DTC only)
- Support for Hella XENON headlamps (Thesis)
- Support for Webasto Hood Control (Spider '06)
- Support for Marelli Body Computer (Guilietta, Ducato) (Info and DTC only)
- Support for Delphi Body Computer (Ypsilon 2011) (Info and DTC only)
- Support for Marelli climate control (Giulietta) (Info and DTC only)
- Support for Marelli climate control (Ypsilon 2011) (Info and DTC only)
- Support for Harrison climate control (156)
- Support for old Allied signal airbags (Marea, 156)
- Support for old BREED airbags (Bravo/Brava)
- Added the ability to read DTC details (parameter values when the error was detected)
- Support for DTC Details of Bosch EDC15C7 CF3/EOBD Diesel Injection
- Support for DTC Details of Marelli 6F3 EOBD Diesel Injection
- Support for DTC Details of Bosch Motronic M1.5.5 Injection
- Support for DTC Details of Bosch ABS 5.7
- Support for DTC Details of Bosch ABS 8
- Support for DTC Details of Marelli SELESPEED CFC208F Automatic Gearbox
- Support for DTC Details of Marelli SELESPEED CFC209F Automatic Gearbox
Multiecuscan 3.4 RELEASED!!!
Re: Multiecuscan 3.4 RELEASED!!!
Great Job as always!
but what about UniAir cars...
I thought it is MultiAir (for example Alfa Mito 1.4 turbo 16V equipped with Marelli ECUs)
I'm pretty sure that the engine of that car is called "multiair", so is it just the name? or not?
It is all about the name (I think)...EnIgMa wrote:Great Job as always!
These cars are with Marelli IAW 8GMF CF5 (1.4 16V).
Hello to all who buy or cables which interface with
Normal 3-pin connector without changes?yani wrote: - Support for old BREED airbags (Bravo/Brava)
Yes! It should be!Dimko wrote:Normal 3-pin connector without changes?yani wrote: - Support for old BREED airbags (Bravo/Brava)
Hello Yani, I wondered why wax when a new version of the PC by opening multiecuscan gave me the new version now no more, I had to manually download the new version 3.4.2 and then installed the strange thing is that the PC after the installation is and had to restart that did not happen before, I have a license before the change in annual contract is changing something for me
regards Mik
regards Mik
Ciao.Aron96 wrote:Hello Yani, I wondered why wax when a new version of the PC by opening multiecuscan gave me the new version now no more, I had to manually download the new version 3.4.2 and then installed the strange thing is that the PC after the installation is and had to restart that did not happen before, I have a license before the change in annual contract is changing something for me
regards Mik
I solved this problem so, I uninstalled the program multiecuscan 3.4.1 then,,
1. Go to the Start->Run... and then enter "regedit" without quotes in the Open field.
2. When Registry Editor opens, go to the /HKEY_LOCAL_MACHINE/SOFTWARE/ and you should find the folder Multiecuscan listed. Delete this folder completely with its content. Choose Yes when you are asked "Are you sure you want to delete this key and all of its subkeys?".
3. Close the Registry Editor.
4. Finally, install 3.4.2 multiecuscan Again.
5. Enter license.
Note. Do not forget to save the license.
Italian.
Ciao.
Ho risolto questo problema così, ho disinstallato il programma multiecuscan 3.4.1 poi,,
1. Vai alla Start-> CMD ... e poi digitare "regedit" senza virgolette nel campo Apri.
2. Quando si apre l'editor del Registro di sistema, andare alla / HKEY_LOCAL_MACHINE / SOFTWARE / e si dovrebbe trovare elencata la cartella Multiecuscan. Eliminare questa cartella completamente con il suo contenuto. Scegliere Sì quando viene chiesto "Sei sicuro di voler eliminare questa chiave e tutte le sottochiavi?".
3. Chiudere l'Editor del Registro di sistema.
4. Infine, installa din nouvo multiecuscan 3.4.2.
5. Inserire licenza.
Nota. Non dimenticare di salvare la licenza.
boun divertimento.
Fiat per sempre..... mai piu.
I get this error message when trying to upgrade from 3.4.1 to 3.4.2.
System: win7, 64 bit.
Any ideas?
Regards,
portello
Any ideas?
Regards,
portello
The file is damaged (incomplete download). Please download the installation file again.
