Hi. I'm hoping somebody can help me please?
I have just purchased the Multiecuscan software complete package with all the leads etc. I have just tried to complete a proxi alignment on my 2006 Stilo JTD 8V and i have come across a problem that says my Body Node and Dashboard Node need EOL programming.
Here is the log file
CAN CONFIGURATION DATA:
00 02 01 2D 00 02 01 2D 00 00 00 00 00 00 00 00 00 00 00 00
00 02 01 2D 00 00 00 09 00 02 01 2D 00 00 00 09 00 00 00 09
30 34 31 39 32 30 32 36 38 34 31 54 45 52 4D 3A 32 38 20 20 20 20 05 07 21 2D 01 02 00 09 00 00 00 D0 00 00 00 00 14 26 00 00 00 44 06 00 14 00 00 00 00 00 11 58 50
Body Computer Node (NBC)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Driver Door Node (NPG)
Passenger Door Node (NPP)
01/02/2012 22:01:01
CONNECTED TO:
FIAT STILO 1.9 JTD
Body Computer Node (NBC):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Receiver Radio/Radio Navigator Node (NRR/RMN):
Driver Door Node (NPG):
Passenger Door Node (NPP):
How can i carry out the EOL programming? I have tried to reduce the latency speed (reduced to 1) and tried the proxi alignment again but i have the same issue. The sequence does not appear to fail as all the nodes show success during the process but i still keep ending up with the same log file errors.
Any help/advice would be gratefully received.
Thanks,
Mick
EOL Programming help
MentalMick
Re: EOL Programming help
hi
have seen today same thing on doblo
what is eol ??
greets wilco1v
what is eol ??
greets wilco1v
MentalMick
I think it sands for end of line. I pressume it is the last bit of the programming on the CAN bus. I know there can be issues I you try and programme it too fast but I'm presuming mine is a faulty instrument cluster.
Mick
Mick
