Option to change km
stefano
Option to change km
Post by stefano »
Since the programs are everywhere to change km, would be nice if it were implemented in the multiecuscan this option. :!:
Fiat per sempre..... mai piu.
Re: Option to change km
Multiecuscan can change odometer values BUT ONLY INCREASE THEM!!!!!!
Also trying to do a "Wrap Round" (set 99999999 hoping it will then step to 000000000) will not work.
stefano wrote:Since the programs are everywhere to change km, would be nice if it were implemented in the multiecuscan this option. :!:
Unfortunately it is not simple as you think...
Yes, you can find programs for changing km on the dashboard, but they are very expensive.
You need minimum 200€ only for software + minimum 100€ for programmer...
It is not that cheap!
orso yoghi
Post by orso yoghi »
I think that the FES can do I just believe that Yani did not want to make this....
left only the possibility of increasing
Juggers2k
Post by Juggers2k »
orso yoghi wrote:I think that the FES can do I just believe that Yani did not want to make this....
Which begs the question, why would you want to do anything else?
If you're fitting a replacement set of clocks (the only legitimate reason to change your odometer reading), then a new cluster will have a lower reading than the one you take out.
stefano
Post by stefano »
Normally, if you can add km means it can and should reduce.
I think if they introduce this feature in the program would have a much greater success in sales.
remains to be seen.....
orso yoghi
one might as happened to me buy a car from a disaster instrumentation and equipment bought used has more km of my car and you get less km in ecu and many more in the instrumentation
stefano
Post by stefano »
is not new, about 90% of today's cars have km change .....
I agree with you both... I would like to have that option too, but I do not think that Yani will add this option because purpose of this software is not dashboard calibration it is diagnostics of different ECUs on the ALFA, FIAT and LANCIA cars… ;)
I'm almost 99.9999% sure even Fiat Examiner CAN NOT decrease the mileage/odometer value.
I think I will also go so far as to say that the "normal" instrument cluster commands / interfaces do not allow the decrease of odometer values.
The tools/hardware/software that allow odometer values to be decreased are "hacks". The original Fiat/Marelli/Veglia/Visteon etc. designs were implemented the way they are (increase only) to try and reduce fraud etc..
Even if Yani could implement a "hack" there is no way he is going to.
Locked
