Hi all,
I used multiecuscan with Clevo notebook without any problem. I have changed my Clevo to HP 620. On HP I have problem connecting to engine ECU (Alfa 166 2.0 TS Motronic M1.5.5.). Program says "No ECU response". If I connect to ABS or airbag, the connection is create without problem.
I'm using KKL interface with PL2303 serial to USB.
Anybody has an idea?
Thans
fejohn123
						M1.5.5 connecting failure
				fejohn1231
Re: M1.5.5 connecting failure
I suspect your serial to usb adapter causes problems
What is your latency time KKL
But trying to set a hook in High Latency Mode
I've found that few serial to usb adapter
can be used
can be used
				fejohn1231
For Clevo I used same serial to usb adapter. I tried the High Latency Mode too, and the all possibilites.
Airbag and abs is stable, M1.5.5. no.
I tried also with Unidiag, that show the connection pass to pass. On the start during the initialization, show me DATA ERROR.
So I think that lower speed will be the problem.
fejohn
fejohn
PL2303 does not support 10400 bps and needs a registry mod to make it support this speed.
You can search here on the forum or internet for this registry mod.
				fejohn1231
Thank You yani! I fond
fejohn
						fejohn
