Ive recently purchased a new un-modified OBDII 16 pin-usb cable, to use with my 3 pin with +&- battery Croc's, so that i can hook up to my 1999 V, 146 Ti, phase 2, 2.0 TS 16v
as far as i can tell, the cable drivers are all in and good, it is all findable, and testable on Port Com 1, and tests at around 11ms.
this is as far as my computer knowledge will get me, but i cannot connect to the ecu despite many many many attempts, tests, and slight variations
please help because this is driving me mad!
cheers
shrew
146 Ti WON'T CONNECT !!!
shrewiside
Re: 146 Ti WON'T CONNECT !!!
The Alfa 146 2.0, the motor control
M2.10.3 or M2.10.4
and for this you need a KKL interface
With your OBD2 interface you can not on this ECU
M2.10.3 or M2.10.4
Yep! Alfaeddy is right!
You need KKL interface...
