Yes it should be more-less that engine ECU type!
Is you are not 100% sure which engine ECU you have in your Alfa Crosswagon that just click Scan button and it will scan all ECUs on your car and later you can know which engine and others ECUs you should use to access them.
Of course ignition should be ON and the interface should be plugged in the car before you click Scan button.
Alfa 156 Crosswagon support
Re: Alfa 156 Crosswagon support
